I've been reading the service manual in preparation to put the A/C system back into my car and found that all A6 compressors are not created equal. Seems non-corvette applications have a displacement of 12.6ci and corvette applications have a displacement of 10.6ci. With that in mind I searched the archives in hopes of finding more about them but didn't find a lot.
I have two compressors, one correct for the car with the superheat switch and incorrect pulley, and one incorrect without the switch and the correct pulley. Since they both pump when turing by hand I figured that I'd swap the pulleys and whaile at it re-seal it. So here's my questions:
While apart, is there a way to determine what the displacement of each compressor is other than measuring the stroke and bore?
In the archives there was some discussion that the larger displacement compressor results in an idling problem. I also read that re-builders don't differentiate beween the larger and smaller displacement compressor. Is anyone aware that they have the larger displacement compressor and has anyone experienced this problem?? The car in question is a '72 LS5 w/ auto.
