1982 Radiator - NCRS Discussion Boards
1982 Radiator
  • Mike R.
    • May 31, 2002
    • 119
    1982 Radiator
    Does anyone have a source for a correct radiator for a 1982? The usual suspects such as DeWitts, Paragon, Corvette Central, etc, all come up with aluminum replacement
    Mike Robb
    • 43296
    Re: 1982 Radiator
    Mike-----
    What you're looking for is a GM #3053440. It was discontinued without supercession in July, 1994. So, it's been gone almost 20 years now.
    What's wrong with your existing radiator? Is it not original? If original, why couldn't it be re-cored?
    • Dick W.
      • 10483
      Re: 1982 Radiator
      Mike-----
      Believe it was available through AC Delco sometime after that. Don't have the old catalogs anymore, but I seem to remember purchasing a few in the last '90's
      Dick Whittington
      • Mike R.
        • May 31, 2002
        • 119
        Re: 1982 Radiator
        Joe
        It's the original radiator and is plugged up. Not surprising after + 30 Years. I am ooking for an alternative to recore but it may not be an option.
        Mike
        Mike Robb
          • 43296
          Re: 1982 Radiator
          Joe
          Mike
          Mike-----
          If the tanks are in good shape, a re-core is, functionally, virtually as good as a new radiator-----maybe even better from the point of originality. That's because SERVICE radiators, depending upon when manufactured, may differ in minor ways from the originals, especially as it relates to the tanks.
          • Jim T.
            • March 1, 1993
            • 5351
            Re: 1982 Radiator
            Joe
            Mike
            Mike, My original owner 1970's radiator is original and still doing the cooling. It has been removed and cleaned by a radiator shop at least once and leaks repaired a couple of times. Still has the original core. Have you taken your 82's radiator to a radiator shop for an estimate for cleaning?
            • Dick W.
              • 10483
              Re: 1982 Radiator
              Mike-----
              In one of my prior lives, among other ventures, I owned a radiator repair shop. The radiators of the mid seventies to sometimes in the eighties (nineties) were not of the same quality as the earlier units. It is my belief that either the tubes were either thinner or made of a different composition. It was not unusual to see a five year old core have so many leaks that they were not worth repairing. Also the tank seams were bad to split.
              Dick Whittington
