1966 390 hp 427 dyno results - NCRS Discussion Boards
  • Jef S.
    • December 15, 2010
    • 118
    What should a completely stock rebuilt 1966 427 390 hp engine actually develop for horsepower at break in on a dyno?
  • Mike F.
    • April 25, 2011
    • 668
    Re: 1966 390 hp 427 dyno results
    You'll need to provide a little more information than that. When you say "stock", how stock? Nothing done to the heads? No decking of the block? Compression ratio? How was it configured on the dyno?
    I would guess that if you pulled a typical 1966 427/390 engine off of the production line and ran it on an engine dyno, you would get somewhere in the 350-375hp (gross) range.
    Here's an article on a slightly modified 427 build. http://www.corvettefever.com/techart..._engine_build/
    • Jef S.
      • December 15, 2010
      • 118
      Thanks that's exactly what they got when the machine shop ran mine on their dyno. 355
      • Mike F.
        • April 25, 2011
        • 668
        Can you post a pic of the dyno sheet? 355hp@???? , xxxtq@????
