new use for old tool - NCRS Discussion Boards
  • Mike M.
    • May 31, 1974
    • 8396
    i've had a snap-on tool HE 53 for years. its primary purpose is to grab the headlite bucket springs and attach the spring to the headlite bezel. i've used it on c-1 and c-2 for years. today i'm installing a set of al knock seat cover bottoms on a 64 vet seat. old Al Knoch has installed the 8 clips on the seat cover assembly that pull the cover down on the foam cushion. its always been a pain to fish a set of needle nose pliers thru the foam and grab the clip , pull clip thru foam and secure the clip to the metal rod that lies on the underside of the foam. the snap-on HR 53 replaces the needle nose pliers nicely. mike
  • Stephen L.
    • May 31, 1984
    • 3158
    Re: new use for old tool
    I use a crochet hook from my wife's sewing stuff to pull the clips thru the foam.....
    • David P.
      • August 12, 2007
      • 146
      Thanks for the tip, guys! That's gold.
      • Brian K.
        • September 19, 2007
        • 174
        I use an old coat hanger bent in a tight U, push it through the foam, attach the hook & pull it through.
        66 Coupe
        66 Convertible
        2022 2LT Coupe
        67 Chevelle SS396
        67 XLCH HD Sportster
        • Harry S.
          • July 31, 2002
          • 5316
          I straightened 3 of the clips last week on my 63 seat bottoms. I started tearing up the foam. After an hour I just gave up.
          I ended up using 14" black plastic electrical ties and cinching them down. Then I cut the excess off. Each seat bottom then took 15 minutes total time.
          If GM had those ties in the 60's do you think they would have used those metal clips?
          • Carl N.
            • April 30, 1984
            • 592
            I have a set of dental tools which work great
            • Wayne W.
              • April 30, 1982
              • 3605
              One of those tire plug installers works well too.
              • Jim T.
                • March 1, 1993
                • 5351
                What tool do the employees of AL Knotch that do the installations at car events use when they are doing the installation?
                • Ray G.
                  • May 31, 1986
                  • 1189
                  Carl; Will those tools be used on teeth after being used on seats?
                  I hope you dance
                  • William B.
                    • August 31, 1984
                    • 57
                    I just bought the tool from Paragon and it worked fine.
                      I use an old manual choke cable with the end of the music wire cut off and bent in a hook - works great for headlight springs and seat work.
                      • Richard M.
                        Super Moderator
                        • August 31, 1988
                        • 11325
                        Mike, A picture of the snap-on tool HE 53?
                        Stephen, Does your wife know that!
                        Harry, I'm tellin' !!!!
                        Ahh, good idea John.
                        Okay.........here's mine, piano wire.
