Any know the color code for the gauge cluster and glove box door. 1963-67 Corvette - NCRS Discussion Boards
  • Claus S.
    • December 30, 2010
    • 414
    I have an extra gauge panel for my car that is in very good condition but i have been thinking of repaint the black on the cluster
    Is the color semi flat black or flat black on the gauge cluster and glove compartment door on 1963-67 Corvette
    Or is there a special color code that is used on the black part of the gauge cluster?
    It is not just to pop in to the a store and buy a Krylon black spray can since i live in Northern Europe
    I can not order the spray cans from the US because spray cans will not be shipped using air freight
  • Brian K.
    • September 19, 2007
    • 174
    Re: Any know the color code for the gauge cluster and glove box door. 1963-67 Corvet
    I used SEM Trim Black in a spray can. Maybe it's available there? The make a lot of auto body supplies.
    66 Coupe
    66 Convertible
    2022 2LT Coupe
    67 Chevelle SS396
    67 XLCH HD Sportster
      • 11669
      Same here. The color is very correct.
      • Claus S.
        • December 30, 2010
        • 414
        I did a search for SEM Trim Black to check if they sell it here and found one place that sells:
        000701 Cockpit Spray Semi Gloss 600ml.
        Only the text and no picture
        I think i found the correct SEM Trim Black 39141- 39143- 39144 paint if it is the same as shown on the picture below?
        If this is the correct paint should i use 39141, 39143 or 39144?
        • Michael M.
          • February 7, 2011
          • 186
          [ATTACH=CONFIG]50553[/ATTACH]
          According to the SEM Technical Data Sheet, the difference is in the packaging/quantity.
          39141 TRIM BLACK Gallon
          39143 TRIM BLACK 20 oz Aerosol
          39144 TRIM BLACK Quart
          http://www.semproducts.com/wp-content/uploads/assets/tds/sem_tds_trim_paints.pdf
          • Claus S.
            • December 30, 2010
            • 414
            I see. But it is the paint that many use for gauge clusters right?
            • Michael M.
              • February 7, 2011
              • 186
              Yes, I have used the aerosol can with great results. It's more convenient for smaller projects like a cluster and glove box door.
              • Claus S.
                • December 30, 2010
                • 414
                Thanks for your help I will order a couple of SEM Trim paint tomorrow
                • Brian K.
                  • 174
                  yes Claus...that's the stuff!! U can use it in a lot of places on your car.
                  66 Coupe
                  66 Convertible
                  2022 2LT Coupe
                  67 Chevelle SS396
