Driving 4000+ miles from California to Florida for Flight Judging! - NCRS Discussion Boards
    • 15671
    #31
    Re: Driving 4000+ miles from California to Florida for Flight Judging!
    Okay, guys, here's the algorithm you need to program into the supercomputer; 225/60R-15s average about 815 revs/mile.
    Speed = RPM(60)/(axle ratio)(tire revs/mi)/trans ratio
    My ancient TI calculator yields 69.6 MPH at 3500 for Luke's car, assuming a 3.70 axle, so his speedometer is reading 21 percent high. My Excel gear chart that I posted here a few weeks ago yields the same result.
    The short tires only account for about 9-10 percent, so I suspect (assuming the tach is reasonably accurate) the speedometer gearing is mismatched to the installed axle ratio.
    If the objective is to accumulate as many miles as possible... the same error applies to the odometer.
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11323
      #32
      After one coffee this morning I counted 10.5 buttons on my flannel shirt. (because one broke in half from the clothes dryer malfunction last week)
      Then after my second coffee and re-reading Lukes email, and Dukes equations, I used my MS calc.exe Stupidcomputer and came up with.....
      210000 / 3015.5 = 69.640192339578842646327308903996 MPH ((3500x60) / (3.7x815))
      Ra-Ro......If his odometer is off, he needs to get something fixed before the next Flight meeting.
      Rich
      p.s. His tires are worn so the error is even worse. However, all of his other equipment may be worn. Remember the car has over 400,000 miles on it, and his odometer gears and transmission speedo gears may be skipping every once in a while, as well as worn tach drive gears.
      So it all could be a wash.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11323
        #33
        I never got a follow up about Luke's return trip until yesterday. Chuck said he heard from him and made it back okay. But he had a slight mechanical issue close to home. A email I got yesterday from John, his CA to FL shotgunner.
        Looks like Luke (Roadwalker) "had the force" with him.
        -------- Original Message --------
        Re: forum link about your journey
        Sat, 8 Feb 2014 11:04:48 -0800
        John Q <>
        RM <>
        Hey Rich
        Well, Luke made it back in about 4 or 5 days....can't remember. One days drive was from about an hour east of the Texas border
        to El Paso.....running about 80-85 mph. He got about 2 hours from his house and pulled off the interstate to spend the night
        with a friend. Just as he came to the exit stop sign and made a turn he heard a loud pop from the engine. He immediately
        stopped the car and opened the hood....the air cleaner had vibrated loose and was laying next to the engine. The support
        rod for the air cleaner was no where to be found, so assumed it went into the intake manifold!!
        To make a long story short, he trailered the car to his shop, pulled the intake manifold and heads and found a broken valve
        spring and no engine damage. Sure enough, he found the air cleaner support in the intake manifold!!
        It's always an adventure ......
        Anyway, hope all is well with you and Chuck....looking forward to a Florida Keys trip
        Best
        John
