rochester carb info - NCRS Discussion Boards
rochester carb info
  • Steve D.
    Infrequent User
    • January 18, 2012
    • 8
    #31
    Re: rockchester carb info
    P1070443.JPGHere's a pic
    • Rich C.
      • January 1, 1994
      • 383
      #32
      Geez, I wish '73 Big Blocks hadn't come with the A.I.R pump...would've saved me a boatload of $$$.
      '73 LS-4 454 Coupe
      '96 LT-4 Collector Coupe
      • David P.
        • August 12, 2007
        • 146
        #33
        That JM Revision team has been in place for several years.
        We are happy to monitor and receive what additional information you generate, however, when we cite a serial number range for changes in the TIM&JG all of those numbers are based on examples we have seen to the point of the JM printing. They are all always approximate, and it would be a mistake to assUme that all BB engines up to a given point had no AIR ports and again at another point changed back. The exhaust manifolds were installed at the engine plant. The engines were installed in Corvettes in no particular order, so there may and probably are gaps in this feature. Good luck with you search. We ill be watching.
        Terry, that's great insight. Thanks. I look forward to following the endeavor to write the 5th edition, whenever it unfolds.
        • David P.
          • August 12, 2007
          • 146
          #34
          Originally posted by Steve Doughty (54338)
          [ATTACH=CONFIG]50418[/ATTACH]Here's a pic
          Beautiful silver 1970 454, Steve! Looks like T-top roof panels and black interior? Any other details you'd car to share about it, like build #/date and any options? I'm preparing my '70 Cortez Silver/Blue March #5864 car for Flight judging. Maybe we can share info. Cheers-
