54 gas tank - NCRS Discussion Boards
54 gas tank
  • Guy M.
    • November 1, 1993
    • 500
    54 gas tank
    Just got my new Quanta gas tank and compared it to the original one and it appears to be 1/2 inch taller. Its a 56, 57 new tank and Im hoping it will fit. CC doesnt list a 53 to 55 anymore. Have any of you put this tank in a 54? Any issues?? Thanks as always
  • Chris S.
    • January 1, 2000
    • 1067
    Re: 54 gas tank
    it will fit
    you will have to bend the lower seam flange over - I mean over.....!!!!
    That is the only tank we have....
    it will fit
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • John L.
      • February 1, 2005
      • 207
      Re: 54 gas tank
      Hey Guy....if you have the opportunity to post a couple photos of the bend it would be great. I will be needing to go down this same road later in the year so a photo reference would be helpful - that is if you have the time.
      Thanks!
      John Lanning
      • Chris S.
        • January 1, 2000
        • 1067
        Re: 54 gas tank
        Take a flange pair of vice grips - if you have them
        if not - a 2x4 and work the flange over a little at a time
        if you pull your orig tank out your will see how the flange is bent
        just have to duplicate it plus a little more
        it is hidden in the well....so no one sees it.....
        • Guy M.
          • November 1, 1993
          • 500
          Re: 54 gas tank
          DSCN0996.jpgDSCN0991.jpgDSCN0992.jpgDSCN0993.jpgHere is a comparison. New Quanta tank came already bent and is 1/2 inch taller
          • Chris S.
            • January 1, 2000
            • 1067
            Re: 54 gas tank
            Whats wrong with the old one ?
            the flange at the bottom - the entire way you will have to roll.....
            it is tight but it will fit
            • Guy M.
              • November 1, 1993
              • 500
              Re: 54 gas tank
              Hi guys, My tank is still average allthough it has baffels and isnt the original. Would cost about $100 to test and clean it up and then I still have an old tank. I think Im money ahead and will sleep better at night knowing my old tank wont develop a problem. For another $100, why not just replace it. It will be interesting to see how tight it is. Seems like this is the only tank available.
              • Chris S.
                • January 1, 2000
                • 1067
                Re: 54 gas tank
                it is the only tank available
                If you dont want the old tank - let me know
                Add it to my pile
                • Guy M.
                  • November 1, 1993
                  • 500
                  Re: 54 gas tank
                  Chris, will the old straps still work?
                  • Chris S.
                    • January 1, 2000
                    • 1067
                    Re: 54 gas tank
                    Yes sir.
                    You will prob have to use longer bolts at the back - to get them started.....
                    • Tony R.
                      • April 19, 2017
                      • 201
                      Re: 54 gas tank
                      Chris is exactly right. Worked on my 54.
                      • Troy P.
                        • February 1, 1989
                        • 1284
                        Re: 54 gas tank
                        While you are at it buy the 56-57 fuel gauge sender too if you don't have a correct NOS sender that you are sure will continue to work. The 53-55 reproduction senders are junk.
                        As you know you will not need the 56-57 pick up pipe since that set up takes fuel through the top of the tank and 53-55 comes out the bottom. So screw a brass plug or bolt with sealant on it into the brass pipe fitting on the top of the sender. Or cut the pipe off below the fitting, crimp the pipe closed and fold it over on itself twice to prevent fuel from ever coming out.
                        • Guy M.
                          • November 1, 1993
                          • 500
                          Re: 54 gas tank
                          Will the 56-57 sender work on 6 volt 54? I have the repro in mine and it sucks. Reads twice as much as whats in it.
                          • Troy P.
                            • February 1, 1989
                            • 1284
                            Re: 54 gas tank
                            That is my understanding. The sender unit is a variable resistor. I believe the resistor is the same for 6 and 12 volt. The difference is in the dash gauge that interprets the current that passed through the resistor and converts it to gauge needle movement.
                            Well that's my theory. Feel free to check it out with a more electrically minded restorer.
