C1 Water Pumps - NCRS Discussion Boards
C1 Water Pumps
  • Jerry B.
    • August 31, 1994
    • 416
    C1 Water Pumps
    I have two different impellers, One cast and one stamped steel . I will be driving the old girl in the Fl.heat. Is one type more efficent than the other. I am using the stock pump for a 62 small block.
  • Jerry B.
    • August 31, 1994
    • 416
    Re: C1 Water Pumps
    Any replies would very much appreciated.
    • Donald L.
      • September 30, 1998
      • 461
      Re: C1 Water Pumps
      The original WP used a cast iron impeller with no problems. From what I have read stamped steel impellers may cause cavitation within the cooling system
      • Jerry B.
        • August 31, 1994
        • 416
        Re: C1 Water Pumps
        Cast iron is the way I going . Thanks much for your input.
          • 43246
          Re: C1 Water Pumps
          Jerry------
          The cast iron impeller is best assuming you have one in good condition. Many of these show serious metal erosion due to cavitation and corrosion. This will often be seen on the rear of the rotor. Among other things, this effectively shortens the shaft orifice. I would not use one that showed serious metal erosion.
          • William M.
            • August 31, 1974
            • 113
            Re: C1 Water Pumps
            FYI - I have new cast iron impellers for small block and big block 1955-1972 Corvette water pumps.
            Bill Mock #93
