Water Pump Rebuild Kit - NCRS Discussion Boards
  • Steven B.
    • June 30, 1982
    • 4011
    Does anyone have experience with water pump rebuild kits, including Zip's, for L-48'sand L-82's? Good sources? Thanks, Steve
  • Patrick T.
    • September 30, 1999
    • 1286
    Re: Water Pump Rebuild Kit
    This might not help but for my '67 L-79, I bought the rebuild kit from LICS. It includes everything you need, even the special tool. Easy to do and it's never leaked. PT
    • Tom L.
      • October 17, 2006
      • 1439
      Did your kit come with the cast impeller shown in the picture? Just wondering, I suspect my rebuilt original that I picked up at Carlisle a while back may have a worn cast or stamped steel impeller, not the cast one as shown. Thanks!!
      • Paul D.
        • January 1, 1988
        • 101
        I had used a Zip's kit a few years ago,still on 327" car with no issues.......Pretty easy if you have a small press......P..
        • Joe R.
          • July 31, 1976
          • 4552
          According to one NCRS member that builds a lot of water pumps and lives in OK., the only kit to use must have a shaft that has been forged and not cast! Forged only!!!!!
          JR
          • Domenic T.
            • January 29, 2010
            • 2452
            One other thing to do before you take the old one apart is measure the distance of the flange to block, that's if your belts look good.
            I found the measurements off on the instruction sheet.
            DOM
