Re: Early '63 Trailing Arm Bolt - Washers or not? - NCRS Discussion Boards
  • Douglas C.
    • September 30, 1988
    • 236
    All,
    I installed the trailing arms on my early (Dec. '62) Convt. last night. In looking at the forum, there was an interesting discussion on this topic a few years back.
    Here's the link ...https://www.forums.ncrs.org/showthre...iling+arm+bolt
    My questions are pretty basic - I have the "corrected - longer bolt" kit from LI Corvettes for early '63.
    Should I... 1. Use the 2 plain washers or not and 2. Where does the lock washer go - I assume under the bolt head.
    Finally I assumed the nut is outboard of the frame, correct? The AIM shows none of these details.
    Thanks in advance for any responses to this question.
    --Doug
  • Douglas C.
    • 236
    Just as an FYI ... I used the lock washer under the head bolt, then the flat washer, threaded the head in-board as shown in the AIM and then used the 2nd flat washer, then the plain (not-hex) nut on the outer frame rail.
    • Douglas C.
      • 236
      • Michael G.
        • November 12, 2008
        • 2157
        Doug, early cars, such as yours, used only one split-ring lock washer on each bolt. This washer was installed under the nut, not under the bolt head. There were no flat washer on this attachment on early cars.
        Much later in 1963 production, when the bolt changed to one with a hole in it, a cotter pin was used in each bolt and flat washers were added under the head of each bolt, as well as under each nut.
        Mike
        1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
        1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
