Rebound Straps - c1 axle help - NCRS Discussion Boards
  • Eric A.
    • December 21, 2012
    • 126
    Need help on stalling the rebound straps. I can not figure out how to install the rebound straps. I have the body off the newly restored frame however I can not push the frame down hard enough to allow for the strap installation. I have had two people pushing down on the rear axle springs but still can not get enough space. In all the photos I can find they are handling loose and don't see to be an issue with installation. I just can not see the fiberglass body weighing enough to push the springs down enough, Any advice or questions.
    Eric
  • Keith R.
    • August 31, 2001
    • 675
    Re: Rebound Straps - c1 axle help
    Eric, the rebound straps can be a bear to install but basically, you need to first flatten the springs. With the weight of the body off the frame, they won't compress unless you rig something up to do this. There was a Restorer article by Joe Calcagno describing how to do this. He created a device involving box tubing, chains and bolts and used a bottle jack to flatten the springs. I used the same tool that he devised and it worked like a champ for me recently. Tip: install the axle U-bolts at the same time that you install and rivet the straps because the springs need to be flattened in order to install those as well. Donald Harris also posted another method to this forum whereby he places a two by four across the frame kickups and then uses ratchet straps to draw the axle upwards releasing the pressure on the straps allowing them to be riveted. Riveting is a whole other challenge. Corvette Central had a rebound strap rivet tool that worked great for me. Part # 581172. When installing the rivets, remember that all rivet heads face the front of the car.
    Keith MacRae
    NCRS #36692
    New Mexico Chapter
    1960 290HP FI
    2013 427 Convertible
    Shade tree mechanic and
    B-52 pilot extraordinaire
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11363
      I've use the heavy duty ratchet straps to pull the axle up to the frame crossmember. This gives you the distance to install the straps. PITA though.
      However........releasing the straps can get a little dangerous, so use caution. By design, the strap will snap pretty loud and release with lots of force. It will also be a good test of how well the straps are fastened when it "rebounds" after the ratchet strap lets go.
      Rich
      • Vinnie P.
        Editor NCRS Restorer Magazine
        • May 31, 1990
        • 1576
        Volume 13 #2, Fall 1986
        • Gary C.
          Administrator
          • October 1, 1982
          • 17929
          Eric,
          Make sure you have the correct length rebound straps for your year model.
          There were multiple lengths used on C1's. Do a search of the Forum for rebound strap posts.
          1958 P&A lists part # 370614 27.25 inches long
          1961 P&A lists part # 374449 29.5 inches long - this part number was the service replacement part number for all C1's even though they were too long
          Searched the forums on "rebound" and found the following information: 1953 - 1958 strap length should be 27.24 inches, 1959 strap length should be 28.36 inches, 1960 is 29.90 inches. The 1960 strap length is longer because the rear sway bar sits the car a lot higher at the rear than the 1958-1959. The strap was shorten to 29.50 inches in 1961.
          Gary
          NCRS Texas Chapter
          https://www.ncrstexas.org/
          • Keith R.
            • August 31, 2001
            • 675
            Originally posted by Gary Chesnut (5895)
            Eric,
            Gary
            The ones I received from CC for my 1960 were the exact correct length. Let me know if you need me to scan and post the Joe Calgango article
            Keith MacRae
            NCRS #36692
            New Mexico Chapter
            1960 290HP FI
            • Vinnie P.
              • May 31, 1990
              • 1576
              See post #4 above
              • Keith R.
                • August 31, 2001
                • 675
                The article I was referring to is entitled "1953-62 Corvette Leaf Spring Installation. Volume 13 #4. I can't seem to extract the article from The Restorer otherwise I would post it here.
                Keith MacRae
                NCRS #36692
                New Mexico Chapter
                1960 290HP FI
                • Eric A.
                  • December 21, 2012
                  • 126
                  VINNIE,
                  was joe's article just one page. I read what you she yearly but only got one page. Driveline only goes back so far so if you have the full article this would help a great deal. Thank you so much,
                  Eric
                  • Vinnie P.
                    • May 31, 1990
                    • 1576
                    Here's the other article Keith refers to...first article was just one page...
                    leaf springs.pdf
                    • Chris S.
                      • January 1, 2000
                      • 1068
                      I have used the ratchet strap method twice - works very well.....
                      I pulled it down just enough to install the straps
                      1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
                      Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
                      1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
                      1957 Corvette - FI 3 sp - Black and Silver
                      • Donald H.
                        • November 2, 2009
                        • 2587
                        Here's a picture of my ratchet strap set up when I installed the rebound straps on my 1960 restoration. Worked great, and yes I was concerned when I released the ratchet straps and whether the rebound straps would hold, but no worries, they did fine.
                        Don
                        Don Harris
                        Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
                        • James F.
                          • March 1, 1997
                          • 51
                          Keith - I was researching rebound strap installation info. On my '61 frame with original rebound straps attached, the rivet heads face to the rear.
                          • Keith R.
                            • August 31, 2001
                            • 675
                            That is correct. And, to rephrase it more clearly - the rivets should be inserted from the rear to the front.
                            Keith MacRae
                            NCRS #36692
                            New Mexico Chapter
                            1960 290HP FI
