C2 Steering Wheel Hub - NCRS Discussion Boards
  • Ralph E.
    • February 1, 2002
    • 905
    This is a last ditch effort. I am looking for a Steering Wheel Hub for my 1967 Corvette with a Standard Column.
    P/N 3900579. All the usual vendors seem to have imported hubs. I am looking for NOS/OEM
    Hoping maybe someone can give me a lead. Help is appreciated.
  • Ray K.
    • July 31, 1985
    • 375
    Re: C2 Steering Wheel Hub
    Ralph
    The #3900579 was replaced by #3923697 somewhere around May of 1969. The P & A catalogs also list this part number as correct for a '68 Corvette with the telescopic steering, but not the standard wheel which requires #3923696.
    Ray
      • 43290
      Originally posted by Ray Kimminau (8917)
      Ralph
      Ray
      Ray-----
      Yes, and the GM #3923697 was discontinued without supercession in September, 1981. However, while the 3923697 is a functional replacement for 1967 with standard column, I vaguely recall that there is some difference, maybe a bit shorter or longer than the 3900579.
      • Ralph E.
        • February 1, 2002
        • 905
        Ray-----
        By any chance was the steering wheel hub used on any other model car. Nova, Corvair?
        • David L.
          • July 31, 1980
          • 3310
          Ralph,
          My 1967 Chevrolet Parts Catalog (Apr. 1967) lists 3900579 in Gr. 6.512 for only the 67 Corvette.
          However, my 1967 & 1969 Corvair-Chevy II--Chevelle-Camaro Parts Catalogs (Oct. 1966 & Oct. 1968) list GM # 3900579 for the following:
          67 CHEVELLE, CHEVY II w/wood grain wheel.
          Dave
          • Ray K.
            • July 31, 1985
            • 375
            Ralph,
            The newer part #3923697 also shows application for the 1967 Chevelle, Chevy II with the wood grain steering wheel,
            additionally -- 1968 Chevelle with wood grain steering wheel.
            As Joe pointed out there may be some minor difference from the original to the replacement number; quite often, not readily visible when comparing the two pieces.
            • Keith B.
              • March 7, 2008
              • 928
              http://www.ebay.com/itm/1967-Corvette-steering-wheel-hub-/161195751963?pt=Vintage_Car_Truck_Parts_Accessorie s&hash=item258803fa1b&vxp=mtr
                • 43290
                Ralph,
                Ray-----
                The 3923697 was SERVICE-only with respect to the 1967 models. It replaced earlier part numbers.
                • Ralph E.
                  • February 1, 2002
                  • 905
                  Keith, that hub looks different than mine.
                  • Ralph E.
                    • February 1, 2002
                    • 905
                    Ray-----
                    Found a 3930062 hub on eBay. Will it be a perfect replacement for my 1967 Corvette?
                      • 43290
                      Ralph------
                      GM #3930062 was originally cataloged for 1968 passenger car with wood grain steering wheel (i.e N-34). It was never cataloged for a Corvette.
                      It is true that the 3930062 was discontinued in December, 1977 and replaced by the GM #3923697, the same part which replaced the GM #3900579 used for 1967 Corvettes. However, that relationship does not necessarily mean that the 3930062 can be used to replace the 3900579. I do expect that it will work but I highly doubt that it will be exactly the same in every aspect of configuration.
                      • David L.
                        • July 31, 1980
                        • 3310
                        The hub listed currently on the Ebay auction (not mine, see link below) as a 67 Corvette hub is NOT. The number on it is "3937896" which is listed in my vintage parts catalogs for 1969 Chevrolets w/wood grain wheel and 1969-1972 Corvettes. It's always good to ask questions when Ebay auction have incomplete descriptions. It's also good to have a library of vintage Chevrolet parts catalogs.
                        Dave
                        • Ralph E.
                          • February 1, 2002
                          • 905
                          Dave
                          http://www.ebay.com/itm/161195751963...84.m1438.l2649
                          Dave, thanks for confirming the ebay linked Hub is NOT a Corvette Hub.
                          I did find another ebay listed hub for a 67-68 Nova or Chevelle, p/n 3923697. Would this one be a good replacement? It looks correct.
                          Have sent seller a list of questions.
                            • 43290
                            Ralph------
                            See posts #2 and #3, above.
                            • David L.
                              • July 31, 1980
                              • 3310
                              Ralph,
                              The hub in the Ebay auction that I referenced is not an original 67 Corvette hub but it is a 69-72 Corvette hub etal.
                              Dave
