What shade of "black" should the steering column "collar" (or spacer...) be painted.....? This is the item that fits around the steering column and into the "notch" in the center of the dash cluster..... Should it match the gloss level of the dash cluster and steering column or is it more flat to statin black.....? I've seen a variety of "shades", but am not sure what is correct.... Thanks....Garry Eastwood #38705
Steering column "collar" on a '64 convertible
Re: Steering column "collar" on a '64 convertible
Gene...
Thanks for the response.... however, should the turn signal shroud, steering wheel hub and the collar/spacer all be the same shade of black.....? My steering column, signal shroud and steering wheel hub are currently a semi-gloss/satin finish..... should the collar match those items....?
Garry Eastwood #38705- Top
Gene...
