Incorrect ECL codes on window sticker - NCRS Discussion Boards
+ More Options
Posts
  • Jim R.
    • June 30, 2001
    • 643
    Ok I thought I would make this a separate thread, I see two mistakes on this reproduction window sticker I had built from Triple A Enterprises one the ECL after the am/fm radio option 2U69DA should be 2U69AA and the other after the 414 interior code 2414AC should be 2414BA am I correct on this I am no expert on ECL's photos are the sticker and pages from 65 corvette Nolan Adams book.
  • Philip C.
    • December 1, 1984
    • 1117
    Re: Incorrect ECL codes on window sticker
    Hi Jim the different letter codes you talking about may have to do with the other options on the car. Phil 8063
      Jim -RPO ECL's are all about what OTHER options are on the car that influence the parts list required to install the RPO in question, and I don't think Triple-A makes any attempt to figure out which ECL any particular RPO should have (some RPO's have as many as 12 possible ECL's, depending on how the car is equipped). If you want the ECL's correct, you have to dope them out yourself.
      Edit: I wrote a feature article on ECL's in the May, 2009 issue of "Corvette Enthusiast" magazine; it's one of the few for which I don't have the as-published .pdf with photos, but I've attached the as-published text (Word document) - it explains what ECL's are all about, how and why they were applied, etc.
      ECL Article.doc
      • Jim R.
        • June 30, 2001
        • 643
        Ok Thanks John so all of them on the order sheet may be right or wrong, I thought by the car being a conv with l76 the codes could only be one code as it shows for that car according to the ECL list in the Nolan Adams book, otherwise I'm even more lost now as to what they should be. Jim
        • Dan H.
          • July 31, 1977
          • 1369
          After two tries to get correct ECLs from Tripple A I did a cut and paste and copied my corrected ones. Even listed the desired ones but 'the computor' he uses only has one entry per option and doesn't consider other variables such as FI etc. Luckily I have a good scanner. Sure could have used that to 'update' my drivers license when much younger!!!!
          Dan
          1964 Red FI Coupe, DUNTOV '09
          • Jim R.
            • June 30, 2001
            • 643
            Originally posted by Dan Holstein (1440)
            After two tries to get correct ECLs from Tripple A I did a cut and paste and copied my corrected ones. Even listed the desired ones but 'the computor' he uses only has one entry per option and doesn't consider other variables such as FI etc. Luckily I have a good scanner. Sure could have used that to 'update' my drivers license when much younger!!!!Dan
            Hi Dan did they charge you for the corrections.
              Jim -
              See the "edit" to my post above - I added an article I wrote that explains all about ECL's.
              • Mike E.
                • June 24, 2012
                • 920
                So if I understand correctly, on an M20 4 speed option the ECL would be different for a base engine car than a L76 car because the base engine would actually be a M20 wide ratio and the L76 car would be a M21 close ratio? Are you saying that Triple A uses the same code regardless?
                Mike
                • Dan H.
                  • July 31, 1977
                  • 1369
                  Yes, called but was told computor sets up each sheet separately as a new one.
                  • Jim R.
                    • June 30, 2001
                    • 643
                    Jim -See the "edit" to my post above - I added an article I wrote that explains all about ECL's.
                    I will thanks John. Jim
                    • Jim R.
                      • June 30, 2001
                      • 643
                      Hi Dan do you have a phone number for them, they haven't replied back to my email. Jim
                      • Dan H.
                        • July 31, 1977
                        • 1369
                        Been a couple of years, can't find my old records. Might have been on my order sheet.
                        • Jim R.
                          • June 30, 2001
                          • 643
                          Ok I wil see if I can find my order sheet. thanks Jim
                          • Jim R.
                            • June 30, 2001
                            • 643
                            Originally posted by Mike Eby (55078)
                            So if I understand correctly, on an M20 4 speed option the ECL would be different for a base engine car than a L76 car because the base engine would actually be a M20 wide ratio and the L76 car would be a M21 close ratio? Are you saying that Triple A uses the same code regardless?Mike
                            Good question Mike, why would 3A even add ECL's after the option codes if there just bogus codes, Authentic reproduction?
                              • 15616
                              Please define: 'authentic.' I suspect it is something like: 'numbers matching.'
