70 M20 Slip Yoke condition - NCRS Discussion Boards
  • Bill L.
    • February 1, 2004
    • 1403
    What does anyone think of the slip yoke pictured below.
    Looks pretty good other than the two grooves towards the end.
    Bill
  • Michael G.
    • January 1, 1997
    • 1251
    Re: 70 M20 Slip Yoke condition
    Bill
    I would feel comfortable with it Bill. No groove where tail housing seal rides. Maybe a little emery cloth and go with it. Now would be a good time to swap out the rear tail housing seal on your tranny if needed.
    • Bill L.
      • February 1, 2004
      • 1403
      Hi Michael,
      I am kicking myself for hesitating on an NOS slip yoke. This used yoke is another option. I also saw where they can stainless steel sleeve my original.
      The bushing and seal have been replaced.
      Thanks, Bill
      • Michael G.
        • January 1, 1997
        • 1251
        Hi Michael,
        Thanks, Bill
        I found and used one very similar to yours. Emery clothed the shaft, cleaned and installed....no problemo. If the surface of the shaft is as good as it looks, clean it up and go with it.
          • 43246
          Hi Michael,
          Thanks, Bill
          Bill------
          I am not a fan of and do not recommend "sleeved" yokes. These are not like brake calipers. When the yoke shaft is machined down, strength is lost. That strength is not restored, at all, by the sleeve. These 63-70 style yokes are thin enough to begin with.
          The used yoke in your photo looks fine to me. The 2 grooves should cause no problem. However, I would highly recommend installing a new bushing in the extension housing prior to installing this yoke.
          • Bill L.
            • February 1, 2004
            • 1403
            Bill------
            Thanks Joe,
            New bushing and seal are installed.
            Bill
