58 leaf springs - NCRS Discussion Boards
58 leaf springs
  • Brandon T.
    • October 23, 2008
    • 872
    58 leaf springs
    My 58 leaf springs has 5 leafs with no groove or numbers on the short bottom spring. Could this be the correct springs or does all the lower leaf have a groove in it?
  • Thomas H.
    • August 31, 2005
    • 1061
    Re: 58 leaf springs
    They should be grooved
    2007 Z06, Lemans Blue
    • Brandon T.
      • October 23, 2008
      • 872
      Re: 58 leaf springs
      Thanks Thomas.
      • Steven B.
        • June 30, 1982
        • 3998
        Re: 58 leaf springs
        If you have 5 leaves that is the HD option--or an added leaf most likely.
        • Brandon T.
          • October 23, 2008
          • 872
          Re: 58 leaf springs
          do the 5 leave springs suppose to have a groove in the lower leave.
          • Gary C.
            Administrator
            • October 1, 1982
            • 17769
            Re: 58 leaf springs
            Brandon,
            All Corvette spring leaves are grooved. If you have a spring leaf that is not grooved, then it's not original to a Corvette.
            Most likely the bottom not grooved leaf was added to fix sagging springs, which was a common practice.
            Gary
            NCRS Texas Chapter
            https://www.ncrstexas.org/
              Re: 58 leaf springs
              Brandon -
              My notes from the late Dale Pearman indicate that the P/N 3748143 RPO 684 5-leaf rear spring had four grooved main leaves and a flat (non-grooved) short bottom leaf.
              • Gary C.
                Administrator
                • October 1, 1982
                • 17769
                Re: 58 leaf springs
                PDF with photos or restored 1957 5 leaf RPO 684 springs of bottom (smallest) leaf grooved. These springs use the second design leaf clamps.
                Gary
                NCRS Texas Chapter
                  Re: 58 leaf springs
                  Gary
                  Gary -
                  Dale's notes refer to '58-up.
                  • Philip C.
                    • December 1, 1984
                    • 1117
                    Re: 58 leaf springs
                    John and Gary you both are correct, when the spring material was rolled out and cut to length they did not waste anything, so sometimes as it rolled out some of the short pieces did not get grooved and were used for the bottom leaf, also it will have the curved tip. I have seen orig cars with one side flat and one grooved. Phil 8063
                    • Gary C.
                      Administrator
                      • October 1, 1982
                      • 17769
                      Re: 58 leaf springs
                      Phil,
                      What you've described sounds possible. But FWIW, I do not recall ever seeing a 1956 or 1957 bottom leaf with no groove, nor have I seen a 1957 RPO bottom leaf with no groove on the half dozen plus Air Box cars we've judged over the years. On the other hand I've not seen every 1956 - 1957 rear spring produced either.
                      Gary
                      NCRS Texas Chapter
