Tags found under seat. 65 coupe. What are they. - NCRS Discussion Boards
  • Ron L.
    • June 30, 1996
    • 58
    I found 2 tags under my seats. Metal. 1/4" high 2" long or so. Blackish color. Number on them:
    sc-3886415-4. And the other says. 4-26. What the heck do they mean? I have a May 23 stl car.
    thanks. Ron
  • Cecil L.
    • May 31, 1980
    • 449
    Re: Tags found under seat. 65 coupe. What are they.
    Probably part number and date for seat or seat springs.
    • Bruce B.
      • May 31, 1996
      • 2930
      Almost every C1 I have owned has had a cloth tag with seat manufacturer information or a hard composite tag embossed with similar information.
      It's nice to find original info on any car or part.
      • Gene M.
        • April 1, 1985
        • 4232
        Ron, interesting you ask about the metal seat tags, because the latest 67 judging manual does not even mention them. I have never seen an original seat without those metal tags. They should receive a deduction if missing.
        • Harry S.
          • July 31, 2002
          • 5330
          The tag is a part number that identifies the seat bottom. There is also a metal tag in each seat back but it contains a different number.
          Depending on where the tag was installed it may be easy or impossible to see when judging.
          • Wayne M.
            • March 1, 1980
            • 6414
            thanks. Ron
            Ron -- on my late 396 convertible, both seat bottoms have the same metal tag as yours (black vinyl interior) SG-3866415-4. And they had a second tag folded with the first around one of the springs with only "7-19" (July 19th, I suppose) embossed.
            The seat back of one of the 396 seats has a pair of embossed tags (first) SG-863371-2, and on the second tag (only) 7-6 (July 6th ?). Haven't had the back cover off the 2nd seat back to check if same.
            On one seat bottom of my early '65 coupe #014xx, STD interior, is a single tag with "SG-3863276". This pair of seats were re-covered, along with new foam in the '80s, so the shop may have discarded them.
            Both cars St. Louis bodies.
              thanks. Ron
              Ron -
              The black tags are part number and date from the company that made the seat frame and spring assemblies (the name escapes me for the moment, but it was European-sounding); they were shipped to Findlay Industries in Findlay, Ohio, who built the finished seats and shipped them to St. Louis, ready for installation.
              • Bruce B.
                • May 31, 1996
                • 2930
                John,
                The name on the cloth tag is easily read and is McInerney Spring and Wire Co.
                I will post a picture of a cloth and some thick paper or composite material tags.
                I believe the cloth tag came off my early 57 although it has a late 1955 date.
                I have a lot more black tags and I will post when I find them.
                Bruce B
                  John,
                  Bruce - Yes, McInerney was the C1 spring supplier. There was another one later for midyears - think it started with an "S", but I can't find it in my notes yet.
                  • Dan A.
                    • May 31, 1974
                    • 1073
                    Ron -
                    I don't remeber exactly either but I think it was someting like _____-VINC.
                    • Carl B.
                      • March 1, 2007
                      • 89
                      66 AO Smith coupe red color metal tags STUBNITZ-VINC 3866415-4-2WK
                        Carl -
                        Yup, that's the name I was referring to for the midyear seat spring assembly supplier.
