ignition switch - NCRS Discussion Boards
ignition switch
  • John C.
    • September 30, 2001
    • 130
    ignition switch
    I want to replace the the switch but not the tumbler, how do I get these apart?
  • Harry S.
    • July 31, 2002
    • 5342
    Re: ignition switch
    Knowing what year car would help?
    • Philip P.
      • February 28, 2011
      • 558
      Re: ignition switch
      You place a pin in the small hole in the key bezel and push in, turn the key I believe counter clockwise t should come out.
      Phil
      • Gary B.
        • February 1, 1997
        • 7064
        Re: ignition switch
        John,
        You have to remove the lock cylinder first. As suggested below use a pin or paper clip with one end straightened out, with the key inserted and rotated fully counterclockwise, with continued CC turning pressure when pushing in the paper clip. That will let you pull out the lock cylinder. After that you remove the peripheral lock ring that retains the switch in the dash. Then pull out the switch from the back side. Hopefully you have a functional key in order to perform step 1.
        Gary
        • John C.
          • 130
          Re: ignition switch
          1959 thanks
          • John C.
            • 130
            Re: ignition switch
            Thanks Phil
