67 turn signal problem - NCRS Discussion Boards
  • Dennis B.
    • May 31, 2004
    • 175
    Re: 67 turn signal problem
    Take a piece of wire and make a good clean ground from your left turn signal (preferably to the bulb socket on the back of the unit) to the chassis. Then test your lights. You may need a helper. I had a turn signal housing on my '66 lose the ground from the socket to the housing due to its age.
    • Ronald L.
      • October 18, 2009
      • 3248
      I have slight twist to this thread in a 1966 right now that never was answered a few years back( Different thread dead ended).
      Symptoms:
      No light at all to the left park/turn.
      Bulb dual filament fine.
      Dash green light stays on when park lamp opened.
      No turn signal either.
      Turn LH was not auto cancelling for years.
      Right side fine and rears OK.
      Sounds like this is in the column terminals and the cam likely broke?
      • Ronald L.
        • October 18, 2009
        • 3248
        #18
        Here is a pretty good how to:
        Steering Wheel, Horn Button, Stand & Canceling Cam Install. When the cam breaks, it will not allow the turn signal to cancel and return the lever to the neutral position. If you have a 1963-1967 Corvette, the cure for this problem is just a phone call and about 2 hours of labor away.
        • Gerard F.
          • June 30, 2004
          • 3805
          #19
          Ronald,
          The 67 signal switch and diagram above is different for a 66 switch.
          However if the the problem is only with your left front park and turn signal light, I would check for an open circuit or no ground to the problem light, before I got into the signal switch in the column.
          Jerry Fuccillo
