Carter Climatic Control (Choke) identification - NCRS Discussion Boards
  • Ruedi K.
    • December 12, 2011
    • 242
    Hello
    Today I took a look at my Carter carburetor and fixed an issue with the choke.
    I noticed some small numbers on the Climatic Control and do not have a clue what they mean.180-50 and 186-79.
    Maybe someone can identify them.
    Carburetor is a Carter AFB 3461 with correct numbers so far.
    Thank you and have a nice day.Ruedi
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11323
    Re: Carter Climatic Control (Choke) identification
    Ruedi, I believe all of those are the Carter manufacturing internal part numbers.
    Just about every part has a stamped, cast, or embossed number on it. Jets, throttle plates, metering rods, bases, etc.
    Rich
    WCFB & AFB parts pics.....
    • Ruedi K.
      • December 12, 2011
      • 242
      Hello RichThank you for the pictures. So there is nothing specific to this choke.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11323
        I remember seeing some Carter documentation with part numbers somewhere. If I can locate it I'll post it here.
        Rich
        • Ruedi K.
          • December 12, 2011
          • 242
          That would be nice.Thank you.
          • Christopher R.
            • March 31, 1975
            • 1599
            Look in your Judging Guide (JG). The housing has a "170" number that is judged. The black Bakelite cover also has a number, but the JG is silent on that number. I see the number "4" a lot. However, the JG for 61-62 is being revised and is due to issued shortly.
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11323
              Ruedi, I looked for that info with the numbers but came up dry. I can't remember where I saw it.
              Good idea.
              • Gary C.
                Administrator
                • October 1, 1982
                • 17650
                Ruedi,
                Send an email to Mike Ernst. Mike's a 61-2 subject matter expert.
                I found this article below about 62 AFB's that Mike wrote for the Restorer Magazine.
                Or send Gary Hodges an email. Gary's the NCRS Carb rep. fuelishgary@live.com
                Recommend purchasing the Restorer magazines on CD-ROM. The CD contains all the previous Restorer articles. Wealth of information.
                Gary
                Choke Assembly: This 1962-only application has a casting number on the back side of 170-575. The choke cover itself has a threaded center extension for the choke heat tube from the top of the right intake manifold. The cover is identified in circular fashion as "Carter Climate Control" and generally has a "170" cast in the top, as well as numbers cast in an indented flat portion.
                NCRS Texas Chapter
                https://www.ncrstexas.org/
                • Ruedi K.
                  • December 12, 2011
                  • 242
                  Thank you for the replies. But this is about my other car, 1963 Corvette. Maybe I confused you with the picture.Ruedi
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11323
                    Ruedi, I have a '63 JG. I'll take a look when I get a chance.
                    Rich
                    • Richard M.
                      Super Moderator
                      • August 31, 1988
                      • 11323
                      My 1963 JG shows a 170-786 is the choke housing.
                      See your PM Inbox.....Rich
                      • Ruedi K.
                        • December 12, 2011
                        • 242
                        Hello RichThank you for the info.
                        • Ruedi K.
                          • December 12, 2011
                          • 242
                          Just found 170-786 on the back of the choke housing. So it's the right one. Thank you.
