1962 T-10 Torque Specs - NCRS Discussion Boards
  • David H.
    • November 10, 2009
    • 777
    Anyone happen to know the torque spec on the bolts holding the tail stock to the case on a '62 T-10?thanks
  • Ron W.
    Infrequent User
    • April 30, 1977
    • 25
    Re: 1962 T-10 Torque Specs
    This is from the Clymer Publications Corvette Handbook, covers 1955 to 1962.
    "Install 3 extension and retainer to case attaching bolts (torque to 35 to 45 foot-pounds) and 2 extension retainer attaching bolts (torque to 20 to 30 foot-pounds). Use suitable sealer on the lower right attaching bolt as viewed from rear". (this is the bolt that almost lines up on a horizontal line with the drain plug).
    Couldn't find a torque spec in the ST-12.
    Hope this helps.
    • David H.
      • November 10, 2009
      • 777
      Perfect. Thanks so much Ron.Especially the part about using sealer. I think maybe that is where I have a slight seepage.
