53 truck engine - NCRS Discussion Boards
53 truck engine
  • Donald L.
    • November 1, 1981
    • 141
    53 truck engine
    I have a perfect running 53 truck engine is any part of this the same as a corvette? Thanks
  • John L.
    • February 1, 2005
    • 207
    Re: 53 truck engine
    Well lets see how close I can get to an answer for you...others may give more in-depth details but my understanding is the truck engine block was used as the basis for the Corvette with the exception of a different cam and impossible head. Of course there are also the hard to find oil pan, intake manifold, valve cover, distributor with tach drive, and water pump that were unique to the first Corvettes.
    • Chris S.
      • January 1, 2000
      • 1068
      Re: 53 truck engine
      If the block is a 911 block - it is the same at the Vette - but the block is stamped differently
      The head for the 241 Head for the 54 and 066 head were for the Vette only
      Some of the small bolt ons can be swapped over - lifter cover, etc.....
      Most of the 53, 54, 55 235 Vette engine parts are Vette only.......
      1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
      Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
      1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
      1957 Corvette - FI 3 sp - Black and Silver
      • Troy P.
        • February 1, 1989
        • 1284
        Re: 53 truck engine
        The Corvette cam is the same as the truck cam. Passenger car cam differs though.
        • John L.
          • February 1, 2005
          • 207
          Re: 53 truck engine
          Thanks Troy for the correction on the camshaft! Was not 100% sure on that fact. John
