Has Anyone used the Luk Flywheel - NCRS Discussion Boards
  • Jack O.
    • July 31, 1996
    • 525
    I didn't ask before purchaing the Luk flywheel for my '69 and now see that it's made in China. Has anyone else used this flywheel?
    Jack
    Jack Ottofaro
  • Bill L.
    • February 1, 2004
    • 1403
    Re: Has Anyone used the Luk Flywheel
    Just installed one on my 70 350/350. No problem. Had balancing checked and it was pretty good. I purchased the LUK flywheel and clutch kit together. Interestingly the pilot bushing that was in the kit was non magnetic versus the one PO installed. Throw out bearing is ceramic but I do not see that as a problem. LUK has been doing this a vey long time.
    I decided on the LUK based on recommendations from this forum.
    Machine shop balanced the assembly again as recommended.
    Finished off the assembly with ARP bolts torqued to spec as recommended.
    Bill
    • Jack O.
      • July 31, 1996
      • 525
      Thanks Bill. I also purchased the flywheel and the pro-gold clutch kit. I have to take it all out though because something is hitting the inside my bellhousing when I turned over the motor for the first time. Actually broke off some small pieces of the bellhousing. Don't know what the heck is going on but since I have to pull it all out and re-do figured I'd ask since I can change if need be.
      Jack Ottofaro
      • Paul H.
        • September 30, 2000
        • 685
        I installed a Luk clutch and flywheel I bought from Carolina Clutch last year in my 65. No issues at all. Good luck.
