Work Bench Build Details - NCRS Discussion Boards
  • Larry B.
    • October 21, 2010
    • 254
    I would like to build a work bench for my newly remodeled garage. I want it to be about 7' long by about 2 feet wide. Does anyone have a plan or parts list for a work bench that they built?
    Thanks, Larry
  • Donald O.
    • May 31, 1990
    • 1593
    Re: Work Bench Build Details
    I have two benches in my "toy room". One is 8' x 30" x32"high and it has a Corian solid surface for a bench top, because it was free. The frames were 2x4's, I can send you a few pix if you'd like.
    The other bench is 139" x 30" x 32" high and is a laminated counter top, also free. The supports are 4 kitchen cabinet base units wit about 6' clear between the two pairs at each end. There is also a metal bracing in the center.
    Both benches support tools, boxes, parts....and me all at the same time.
    Both benches have kitchen wall cabinets above with recessed fluorescant lights, all were also free.
    Counter tops can be purchased already laminated to the length you desire at you local big box store like Home depot, Menards, Lowes, etc.
    Don
    • Mike M.
      • July 24, 2011
      • 297
      Larry: Go to
      garagejournal.com
      for a world of infornation regarding workbenches (and everything else re a garage.)
      • Larry B.
        • October 21, 2010
        • 254
        Thanks guys
        • Dale C.
          • November 1, 1999
          • 844
          Larry
          Remember, it's what it's called a WORK BENCH, function over looks. I made my car cost too much to risk driving and my work bench too little to care if abused. Got one right but would have saved a lot of $$$'s by doing it the other way around.
          Dale
          • Larry B.
            • October 21, 2010
            • 254
            Dale, Functionally and durability is what I am looking for!
            • Joe R.
              • May 31, 2006
              • 1822
              Originally posted by Mike Martin (53605)
              Larry: Go to
              garagejournal.com
              Mike,
              Right on! There is a lot of good info there, make sure you check out the forums.
              Joe
              • Dennis O.
                • December 1, 1988
                • 438
                I built mine with 4X4 legs and 2X6's and a few 2X4's for cross pieces. I wanted it to be SOLID. For the top, I used 2 pieces of 3/4 plywood screwed and glued together. I made it sized so the top could be a standard 8 ft counter top from Home Depot, Lowe's etc. on top of that. I got one with the backsplash (to keep things from falling off the back) and in a light color (which makes finding things on it easier). Because the counter top is not the most durable surface, I designed it so it could easily be removed and replaced. I think a replacement counter top is less than $80. I have had it on for 5 years now and am very happy with it. It's not even close to needing the top replaced yet
                • Gary C.
                  Administrator
                  • October 1, 1982
                  • 17971
                  Dennis, the top could always be covered with sheet metal. Gary....
                  NCRS Texas Chapter
                  https://www.ncrstexas.org/
                  • Dennis O.
                    • December 1, 1988
                    • 438
                    The welding table, sure; but the workbench? Not in my shop.
