54 wiper vacuum - NCRS Discussion Boards
54 wiper vacuum
  • Brad H.
    • August 12, 2007
    • 724
    54 wiper vacuum
    Hi, on a drive with a little rain I noticed wiper's work very slowly and wont return unless radio and or heat is off. What would boost the vacuum so wiper's work correctly? Thank you, Brad.
  • Mike M.
    • May 31, 1974
    • 8410
    Re: 54wiper vac.
    radio and heater don't impact the engine vacuum which is what poets the wiper motor. they are usually slow because the seal in the flapper valve isn't sealing properly(either seal shrinks or the pot metal wiper housing warps). i'd look for an now wiper motor. or stay outa the rain. regards,mike
    • Brad H.
      • August 12, 2007
      • 724
      Re: 54wiper vac.
      Hi Mike, can motor be taken apart and check inside's and or the flapper be redone? Brad.
      • Mike M.
        • May 31, 1974
        • 8410
        Re: 54wiper vac.
        i've disassembled many trico vac wiper moters and used vaseline to coat the seal that is sandwiched between the matal os the flapper alve. sometimes its helped iff the potmetal isn't warped. its a simple job. good luck, mike
        • Brad H.
          • August 12, 2007
          • 724
          Re: 54wiper vac.
          Hi Mike, thank's for the info, will do some checking.
          • Jim L.
            • September 30, 1979
            • 1817
            Re: 54wiper vac.
            I've played with re-sealing these vacuum motors but never had much luck doing so. The seals in the ones I had were too shrunken to respond to any additive I could think of. I ended up sending the motor for my '54 to D&M Restorations in South Carolina and it came back in perfect working order.
            Jim
