Mounting Original 45 year old Goodyear Redlines - NCRS Discussion Boards
  • Gary H.
    • June 8, 2008
    • 308
    I am going to mount some NOS goodyear redlines to use for judging only. I am driving to Kissimmee on my radials and will swap tires when I arrive.
    Should I use a tube inside the tires? I know that they are tubeless but would I be better off using a tube?
    Gary
  • Kenneth B.
    • August 31, 1984
    • 2091
    Re: Mounting Original 45 year old Goodyear Redlines
    If they seal around the rim & no cracks in the sidewall that leak you shouldn't need tubes as you will ony drive to the judging field. GOOD LUCK.
    • Jerry G.
      • April 1, 1985
      • 1022
      More dogmatic sillyness. Cut people some slack on modern tires as long as they are similar size and aspect ratio, don't do deduct on these any more. Jerry
      • Jaime G.
        • April 1, 1988
        • 480
        its only 3 points. Why go thru the hassle?
