58 Chassis Frame - NCRS Discussion Boards
58 Chassis Frame
  • Eric S.
    • April 1, 2002
    • 25
    58 Chassis Frame
    Re: Frame Rot
    I've re-joined membership after 10-yrs. Frame rail has steel plating to surround rust by front leaf spring hanger, a surprise I found after purchasing the car in 2000. I just now fix the frame rail above the rear cross-member. I think I can add more steel plating over the existing steel plating where a little rust is coming out again.
    Bottom line is I can still enjoy car right now and make top side look good, without 1-yr down time to change to new frame and make car more valuable to someone else in the future.
    Aloha,
    Eric
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12800
    Re: 58 Chassis Frame
    Originally posted by Eric Sakai (37816)
    Re: Frame Rot
    Aloha,
    Eric
    Might not be needed to replace the frame, just cut out the rotten bits and well in new pieces of similar material... (see http://www.c2registry.org/index.php?...s&wl_id=10&n=4 and next pages in my C2 weblog)
    Rob.
    NCRS Software Developer
