I am needing a set of window channels (they are the "L" shaped with fuzzies) that the windows slide in. Anyhow have a set of repos but the curve is not right. Does anyone make correct fitting pieces?
Who makes 67 coupe window channels that fit
Re: Who makes 67 coupe window channels that fit
Scott your correct and I have both sides. The rolled edges match perfectly with the stainless glass wiper piece. My problem is on the curve of the rear of the coupe door. When you match the old and new bobble clips up the curve in channel does not match up between old and new. Maybe I need to be on look out for a nos set. ANYONE?- Top
