1966 Corvette and K19 - NCRS Discussion Boards
    • 15616
    Re: 1966 Corvette and K19
    Originally posted by Tim Gilmore (16887)
    I wouldn't think it would be a 100% deduction for the carb if only the date and part number are incorrect. If the carb is visually correct or close to correct, I would expect no more than a 50% deduction.
    Close Tim.
    CDCIF. D= date, so that is a 20% deduct of the available originality points.
    First C = Configuration. If the numbers are not the right ones there is a slight configuration difference for those numbers, however, there may be other configuration differences (where ports are, shape of base, etc) so this may result in a further deduction but not more than another 20% and likely less than that.
    The judging score sheets are available on this site. Click on MEMBER SERVICES on the radio button bar above. Second from the bottom item is SCORE SHEETS. Let your mouse do the walking from there.
