finish on c-2 A-arms - NCRS Discussion Boards
  • Donald O.
    • May 31, 1990
    • 1593
    Re: finish on c-2 A-arms
    Originally posted by Michael Hanson (4067)
    Yes, that's correct. At least for 63 through late 70's or 1980. The entire control arm is coated, before the ball joint is riveted in place.
    Shouldn't they be dip-painted/coated too?
      • 11692
      Michael----
      This photo is of a 1980-82 model. Note the aluminum differential housing and integral aluminum crossmember. So, we know this a-arm paint configuration was in use by that period. Just when it started is still up-in-the-air.
      I think it's 78-79, but that's just my vague recollection.
      I don't own the 78-9 JG, and have no idea if that's in there or not, but that's where I'd look.
      • Michael H.
        • January 29, 2008
        • 7477
        #18
        Donald
        If you mean the ball joint, it was not coated/painted. For 63-67, the ball joint was the only part of the control arm assembly that wasn't painted.
          • 43281
          #19
          Patrick------
          We could figure it out pretty quickly if some folks with later unrestored C3's would make a quick and easy observation of their front upper a-arms. I'm pretty sure the unpainted outer ends did not begin until at least the 1973 model year (and, most likely, well after that). So, folks with 1973-80 would be the "target observers".
          I don't think the unpainted ends ever applied to the lower control arms.
          An interesting question remains as to WHY the change in the painting of the upper control arms occurred. In general, GM does not paint the areas of parts that mate with another part, especially in the case of major functional components. However, in the case of these upper a-arms, they were completely painted for MANY years. Then, the process changed. I've got to believe there was a reason for this and I suspect that it related to some in-service problems. I don't think it was related to some convenience or expediency of the painting process because, if it was, I would expect that it would either have been done much sooner or the change would have been applied to the lower a-arms as well.
          • Ronald L.
            • October 18, 2009
            • 3248
            #20
            The thread is getting bit confusing to follow. a 63 has a tar coating on it, Michael is saying correct to the 1070's being when the control arms were painted (that's not C2). Upper A Arms had ball joints riveted at the asy plant and service. I have a service lower A arm that has a service bolted on ball joint and it was that way when I bought the car in 1978. Joe, are the service part book descriptions in the mid 70's that clear that they include ball joints?
            Second reason is - I bought in 1980 ball joints and the rivets to rivet them back as original and it was a PITA to get that done back then.
            Preference all around was to bolt them on.
            • Paul J.
              • September 9, 2008
              • 2091
              #21
              The tar coating is on top of the paint that we're talking about and was added after the suspension was assembled.
              • Mike M.
                • May 31, 1974
                • 8408
                #22
                i'm pretty sure the tar coating was present on the 63 and 64 a arms when they left st louis. since i believe the 65-7's didn't get the front suspension blackout like the 63 and 64's, i'm inclined to not blackout the ball joints of the 65-67 a arms. mike
                • Michael H.
                  • January 29, 2008
                  • 7477
                  #23
                  Mike
                  The control arms for all 63-67's, (and 68 and newer) were already coated in black when they arrived at the St Louis plant. The final blackout didn't have much/anything with the control arms.
                  For 63-64, the entire front knuckle/brake assembly was already coated when it arrived at St Louis too. (obviously not for 65 and later though) No further major blackout on the chassis line was required for the front suspension/steering for 63-64.
                  We do see some minor blackout overspray on a few items of the front suspension though. Sometimes the coil spring has a light coat on the forward coils. That overspray comes from the shot of chassis black on the top of the front stabilizer bar.
                  Most of the final blackout just prior to body drop had to do with the exhaust system.
                  Most of the complete rear suspension/drive was already black when the entire unit was bolted to the frame.
                  It's difficult to explain the specific areas that were coated and when it occurred. I should take an hour and try to describe the process. I think a lot of folks are confused about this process. Or, I should say, processes.
                  What parts/components were already coated when they arrived at the St Louis plant and what components/areas were coated during chassis assembly.
                    • 43281
                    #24
                    Ron-----
                    The P&A catalogs were always clear that the upper and lower a-arms included the ball joint except for the 1978-82 lower a-arms which were also SERVICE for 63-77. For those, it did not specifically say they included the ball joint. However, every one of those arms I have (four NOS) and every one I have ever seen DO HAVE the riveted ball joints.
                    • Ronald L.
                      • October 18, 2009
                      • 3248
                      #25
                      One thing some seem to be missing and I think I've seen it posted here before is that the early C2 had bare steel then tar coated at St Louis.
                      Go back and read Dan Holstein's comments about his 63.
                      Joe, the the with or without, will have to get the photos when I get back up to the north of what was purchased in '76 and '80.
                      • Donald O.
                        • May 31, 1990
                        • 1593
                        #26
                        Donald
                        No, no ball joint. Just the A-arm.
                        • Michael H.
                          • January 29, 2008
                          • 7477
                          #27
                          Donald
                          I suppose the control arms may have been dip painted. I don't know for sure though. They arrived at the St Louis plant already painted.
                          • Page C.
                            • February 1, 1979
                            • 802
                            #28
                            We use to own a low mileage 1981 that had the original ball joints. The upper A arms were paint like the C2 Corvettes. The 1982's went to the throttle body fuel system but I can't tell from the assembly line photo what type of fuel system that car has installed on it.
                            • Ray G.
                              • May 31, 1986
                              • 1189
                              #29
                              Ray------
                              SERVICE upper and lower 63-82 Corvette control arms were always supplied only with attached ball joints. However, the control arm shaft and bushings were never supplied with the SERVICE control arms.
                              For PRODUCTION the arms were supplied with the shaft and bushings but without installed ball joints. The ball joints were installed at St. Louis.
                              Joe;
                              Thanks.
                              Maybe that is were I got the idea the ball joint end of control arms were not painted to facilitate fitment of the ball joint and rivet.
                              I hope you dance
                              • Michael H.
                                • January 29, 2008
                                • 7477
                                #30
                                Ok, now that we've concluded that the assembled control arm with shaft and bushings, but minus ball joint, arrived at the St Louis plant entirely coated in black, when did the coating change from chassis black (tar base/goo) to a form of enamel?
                                The arms on 63-67 were coated with chassis black but at some point in the C3 era, I think that changed.
