69 Stingray fender script - NCRS Discussion Boards
  • Gary H.
    • June 8, 2008
    • 308
    Does anyone have a good closeup photo of the dot on the " i " in stingray on an original fender badge?
    What are the lengths of the attaching stud?
  • Paul O.
    • August 31, 1990
    • 1716
    Re: 69 Stingray fender script
    Gary
    Can not tell you the length of the studs but from memory originals had 4 studs and later service and productions had 3 shorter studs. Here are a few photos.DSC08247.JPG$_12.JPGIMGP1295.jpg
    • Dave S.
      • August 31, 1992
      • 2930
      Gary
      Can not tell you the length of the studs but from memory originals had 4 studs and later service and productions had 3 shorter studs. Here are a few photos.[ATTACH=CONFIG]49589[/ATTACH][ATTACH=CONFIG]49590[/ATTACH][ATTACH=CONFIG]49591[/ATTACH]
      I don't have a photo but originals do not have a "groove" under the dot on the "I".
      • Edward B.
        • March 29, 2013
        • 691
        Here you go Gary. And original studs are approx 5/16" long while repops are shorter.
        Ed
        • Gary H.
          • June 8, 2008
          • 308
          I wonder if there is 5/16 sticking out when installed on car. First set of repros I had were 5/16 in total length. New ones I found are longer, so approx 5/16 will stock out through the fiberglass.
          • Edward B.
            • March 29, 2013
            • 691
            It's really difficult to get a ruler in there and see what it is, but I believe it's 5/16" total length. I don't have a loose emblem to check. Maybe someone else does?
            Ed
              • 43281
              Ed
              Ed-----
              The original studs were much longer than 5/16".
              Quite some time ago I posted several photos of an NOS original emblem (from the 1969 period). They should be somewhere in the archives.
              • Edward B.
                • March 29, 2013
                • 691
                Joe, the TIM&JG states "Original script attaches with adhesive and four long-positioning studs (ca. 5/16 inch) without nuts". I stood on my head, jammed my camera in there and put the ruler to mine and you're right, it's longer than 5/16". Difficult to measure exactly, but definitely longer than 5/16"!
                Ed
                • Gary H.
                  • June 8, 2008
                  • 308
                  Thanks for all of the info.
                    • 43281
                    Ed
                    Ed------
                    That's the length minus the thickness of the fiberglass. The bare stud is longer.
                    • Mark D.
                      1984-96 Team Leader
                      • June 30, 1988
                      • 2168
                      Kramden
                      • Gary H.
                        • June 8, 2008
                        • 308
                        How were these attached at the factory? The new ones all have an adhesive backing that you just peel and stick on the car. Should I remove the adhesive backing and use some other type of product?
                        • Edward B.
                          • March 29, 2013
                          • 691
                          Nope. According to the TIM&JG, that's how they were applied at the factory. No nuts, just the adhesive backing. However, the AIM clearly shows on UPC 11/13, Sheet A10, that a P/N 9419753 nut was used, but there's nothing in the "Mandatory Installation Sequence" regarding this. No nuts on any of my studs.
                          Ed
                          • Bob I.
                            • November 9, 2006
                            • 265
                            I measured the stud (11/16") from a 1970 emblem.
                            Bob
                            • Edward B.
                              • March 29, 2013
                              • 691
                              Hee's something interesting. I took a look at the driver side and found the stud to be MUCH shorter than the passenger side I had posted pictures of before. I'm wondering if my passenger side is a repop. There's no way I can get a ruler in the driver side, but you can clearly see by the picture (attached) that it's not the same as the passenger side.
                              Ed
