63 Questions - NCRS Discussion Boards
63 Questions
  • Ralph P.
    • February 1, 1990
    • 253
    63 Questions
    1. Color of original glass
    2. Primer color
    Thanks!
  • Michael G.
    • January 1, 1997
    • 1251
    Re: 63 Questions
    Original glass on my '63 is cream/white with primer being red.
    • Tom A.
      NCRS Body & Paint Advisor
      • May 31, 1986
      • 138
      Re: 63 Questions
      Check the manual for glass color. There are two possibilities depending on build date.
      • Tracy C.
        • July 31, 2003
        • 2739
        Re: 63 Questions
        Ralph,
        The early 63s used cream colored panels. But as mentioned they gradually moved towards grayish panel throughout the year. My car was build the last week of production and predominately built with grayish panels. Cars built during the middle of the year will have some of each color.
        The primer color was red oxide directly on the fiberglass followed by a medium gray coat of sealer just before the color coat was applied.
        tc
        • Tom A.
          • May 31, 1986
          • 138
          Re: 63 Questions
          The change took place approximately vin 11000 with a tolerance of about +/- 2000. Combinations of both colors possible on transition cars. Grey glass varied from light to dark.
          • Michael G.
            • November 12, 2008
            • 2158
            Re: 63 Questions
            The timing of the color change may have varied a bit more than 2000 cars after car 11000. Car 13696 has mostly white panels, but both lower front fenders are grey, so things were still mixed up at that point.
            Mike
            1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
            1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
            • Wayne W.
              • April 30, 1982
              • 3605
              Re: 63 Questions
              Things were well mixed for a long time. The early ones also had gray primer like the C1s. I don't know how long that lasted.
              • Rob M.
                NCRS IT Developer
                • January 1, 2004
                • 12884
                Re: 63 Questions
                2. Primer color
                Thanks!
                mmm, my (window) glass is just transparent (actually green tinted ;-)
                Rob.
                NCRS Software Developer
                • Gary F.
                  • August 29, 2010
                  • 248
                  Re: 63 Questions
                  #10,862...Gray doors, tail lamp panel, door hinge pillars & lock panels.
                  Rust primer.
                  • Harry S.
                    • July 31, 2002
                    • 5349
                    Re: 63 Questions
                    13356 all gray except conv. deck.
                    • Joe R.
                      • July 31, 1976
                      • 4552
                      Re: 63 Questions
                      10,3XX Coupe all white!
                      11,8XX Roadster all White!
                      14,4XX Coupe all light gray glass
                      • Wayne M.
                        • March 1, 1980
                        • 6414
                        Re: 63 Questions
                        '63 Fuelie VIN 07055, nude.
                        c
                          • 6960
                          Re: 63 Questions
                          My 63 #10674 Had one white door , lower front fenders- white, rear convertible deck lid- white, lower valance-white, all other outside panels lt. gray.
                          • Philip C.
                            • December 1, 1984
                            • 1117
                            Re: 63 Questions
                            2. Primer color
                            Thanks!
                            #1 was long change over.
                            #2 I would think depends on paint color, primer color would contrast paint color to show coverage. Red over gray, silver over red etc. Phil 8063
                            • Tom A.
                              • May 31, 1986
                              • 138
                              Re: 63 Questions
                              There were only two colors of primer as Tracy indicated earlier. Red primer on fiberglass followed by light grey primer. The light grey acted like a guide coat as the majority was sanded off to level the surfaces.
