Pilot Bushing ID Smaller After Install? What! - NCRS Discussion Boards
  • Timothy B.
    • April 30, 1983
    • 5194
    Re: Pilot Bushing ID Smaller After Install? What!
    Jack,
    IMO, that is the outside of the bushing as you state.
      Originally posted by Jack Ottofaro (28026)
      Ok, got the GM bushing. Just to be sure I don't go through this a fourth time, can someone confirm that the attached picture of the bushing is showing the outer side, i.e. away from the crank? The 'back' end of this bushing is different from the other bushings I installed and rather than simply being flat it rounds out from the edg to the center and is only a flat area in the center roughly 3/16" wide. Thanks.
      [ATTACH=CONFIG]49534[/ATTACH]
      Jack -
      Looks OK to me. Photo below is from my stock of original GM bushings, and the chamfered/radiused side faces the transmission - the newer ones apparently have added the longitudinal slots.
