Rear license plate frame - NCRS Discussion Boards
  • Stephen W.
    • June 30, 2013
    • 50
    Is the rear license plate frame supposed to be the same as the front (stainless, with a compression spring clip on one end)?? '66 L79 Vert #1241
  • Don H.
    Moderator
    • June 16, 2009
    • 2285
    Re: Rear license plate frame
    yes,
    the spring holder clip is on both sides.
    re. below, your frame is missing one spring clip. I think all the vendors sell the repro frames, but none are "correct". The repros will not hold a magnet and the rivets holding the clips are wrong and the clips lack the patent nos. of originals. LICS is a vendor that many like for "most correct" repros. Others like KEEN, ZIP, Paragon and CC.
    • Stephen W.
      • June 30, 2013
      • 50
      Thanks-- I noticed that the Front frame (repro) I got had a hole in the side where there wasn't a spring clip-- is this incorrect for the front as well as the rear?? Know where I can get correct repros??
