I removed the original heater core from my no a/c 1966, before it started to leak. I wanted to give the business to a friend who owns a radiator shop. He thought the old one looked great, would test it, and suggested I reuse it. He said it would be a better core that what he could purchase new. I originally planned to install a new one that was not made in China, figuring new had to be better than one made in 1966. Any help with the decision to replace it or reuse the old, would be appreciated.Thanks,Ken
1966 Heater core
Tags: None
- Top
Re: 1966 Heater core
Kenneth,
You have heard the saying "if it ain't broke don't fix it", I think it's a good idea to have it checked though and while the heater box is out consider installing new door seals.
Sometimes I go for a ride with my 67 and turn the heater on low and I have noticed the heater box door gaskets are leaving little tel-tales on the floor.- Top
Frank,Timothy,and Carl, I appreciate your help in making this decision. I see Doc Rebuild has the door gaskets, rivets, and instructions to repair the heater box doors. Would it be a good idea to solder the heater hose tubes to the core assembly?Thank you,Ken- Top
I've attached our chapter newsletter with an artice about rebuilding the box.Attached Files
- Top
Ken-------
Keep this in mind: heater cores have a life. Let's describe it like this: when a heater core is brand new, it rates 100 on a scale of 100 to 0. When it starts leaking, it rates 0 on that scale. In between, it rates somewhere between 99 and 1. During this entire phase of its life it will test out just fine, will work properly (if not clogged), and will not leak.
So, the question you have to ask yourself is just where is your 47 year old heater core on this 100 to 0 scale? Given the effort and time involved in replacing a heater core, I'd want it to be a lot closer to 99 than to 1 but I expect yours is way closer to 1.In Appreciation of John Hinckley- Top
Very well chosen words Joe L! Simply put a 47 year old heater core should be replaced with a new core unless you want to go thru this exercise every 10 years or so. Like the above poster! Changing a heater core in a 66 once should be enough exercise to last a lifetime!
JR- Top
Harry, Thank you for the newsletter and the great article on the the heater box rebuild. Your club looks like a great social happening. Joe Lucia and Joe Ray, Your case for new heater core replacement got my attention. I guess I am left with the predicament of, will a new core perform better than my old one? Thanks for all the great help. Ken- Top
Kenneth,
If you purchase a new core make sure it's pressure tested good before you put it in the car.- Top
