BB valve rocker arm studs -- early iron vs. aluminum heads - NCRS Discussion Boards
  • Wayne M.
    • March 1, 1980
    • 6414
    Attached 1967 TSB discusses the problem of rocker arm studs pulling out of the head, and the solution. Interesting factoid that the factory (Winters foundry ?) started installing helicoils in all aluminum heads (ie. the first design cast 3904392's) as of May 22nd 1967, and I assume on all aluminum heads thereafter (ie. the 3919842s and the 3946074s).
    P&A30 parts catalogs history shows the first design stud (ie. for '65-66) was #3860006.. Then for a short period of time (5-67 to 6-67) service was to use #3904395; after that the stud # was (and still is) #3921912. The stud for aluminum heads (longer thread, per Roger Gibson article in Restorer of Summer 1991) was # 3904396, per info circled in green in 2nd pic), and I'm guessing, was installed in the early aluminum heads. Anyway, this # was replaced in service, by the same 3921912 in 11-68. Don't know why this would have been so late if there was a problem with the aluminum heads 18 months before that .
    The stud shown in the 2nd pic is from a set of oval port cast iron heads # 3917215, dated B-18-8, and I have no reason to doubt that it is period-correct, and therefore is # 3921912; 2.0" overall length. Anybody got a pic of the earlier part #s ?
    Couldn't resist posting the 3rd pic of the outside temperature this morning, here, in Calgary Alberta. That's minus 29.5 C (or minus 21 F) Wind chill brings it close to minus 40, in either temperature scale.
  • Martin M.
    • November 1, 1979
    • 124
    Re: BB valve rocker arm studs -- early iron vs. aluminum heads
    And did you go outside to take the picture?? Only a Canuck
    Marty McDonough
    '64 No3, 19201
    Beautiful Pahrump, NV.
    No smog, no rain, no winter, no hurricanes, no tornadoes,
    no earthquakes, no forest fires, but prime rib 24/7, and an NHL hockey team in LV.
    vetteheads.com alumni, Boston MA alumni
    1963 NOM Split, 1963 Orig Split 340, 1963 Red Vert Ex NCM opening display car
    1970 Coupe, 1985 Coupe Road Warrior, 1986 Vert
    1932 Ford Highboy Roadster TPI, 1932 Chev 4 Dr Confederate Sedan
    1957 Chrysler 300 C 392 Hemi Car
    All for sale - most not cheap!!!
    • Patrick B.
      • August 31, 1985
      • 2003
      I have Jan, Feb and March 67 3904392 heads and they all have helicoils. I've never seen one without helicoils for the rocker studs.
        • 15706
        It was worse with the valve spring situation. Early SHP big blocks that were run hard suffered a lot of valve spring failures early in life, but it wasn't until around 1969 that the second design dual spring showed up to replace the early spring/damper design.
        Chevrolet seemed slow to recognize and fix design problems back then.
        • Wayne M.
          • March 1, 1980
          • 6414
          Marty McDonough
          '64 N03, 19201
          Marty -- it's so cold up here that I lost a half-gallon due to shrinkage . Took the thermometer shot through the kitchen window.
