Tach too fast - NCRS Discussion Boards
Tach too fast
  • Steve V.
    • June 27, 2011
    • 95
    Tach too fast
    Just cranked up my 1960 230 hp engine after sitting for a year of so. The car did not come with a tach drive distributor and I added one recently. The tach reads way to fast. It goes all the way straight down at 30-40 mph. What could be the problem/
    Steve
    Opportunity is missed by most people
    because it is dressed in overalls and looks like work.
    Thomas Edison
  • Roger W.
    • January 29, 2008
    • 572
    Re: Tach too fast
    The distributor driven tach is different than the generator driven tach. You will need a tach that is specific for distributor drive.
    • Steven B.
      • June 30, 1982
      • 4010
      Re: Tach too fast
      Steve
      Steve, your engine used a generator driven tach, which drives at a different speed than the distributor drive. You should have the generator drive. Steve
      • Steve V.
        • June 27, 2011
        • 95
        Re: Tach too fast
        OK guys, sorry for not proofreading my post. I installed a tach drive GENERATOR not distributor. Tach reads to fast with the generator drive.
        Steve
        Thomas Edison
        • Bruce B.
          • May 31, 1996
          • 2930
          Re: Tach too fast
          Steve,
          The generator driven tach runs twice as fast as a distributor driven tach.
          So your tach sounds like it needs to be distributor driven which is 1/2 the speed of the generator drive.
          I might have a generator tach if you need one.
          Bruce B
          • Joe R.
            • July 31, 1976
            • 4552
            Re: Tach too fast
            Steve,
            This problem is solved by re-calibrating the tach. ANY, well nearly ANY of the advertisers for instrument restoration in the "Driveline" can supply this service.
            JR
            • Steve V.
              • June 27, 2011
              • 95
              Re: Tach too fast
              Interesting Bruce, Why would a 230 HP car have a distributor driven tach? Is there any way to tell externally if the tach was designed for a distributor drive. Is the redline different? This one redlines at 5500. The car came with a non tach drive generator and a HEI distributor when I got it. What's involved it removing the tach? I have had the cluster out and replaced all the wiring but have not removed any gauges as they all work OK.
              Steve
              Thomas Edison
              • Steven B.
                • June 30, 1982
                • 4010
                Re: Tach too fast
                Steve
                Steve, from the factory the 230 HP had a generator driven tach. The redlines are different for hydraulic vs. mechanical lifter engines: 230, 245, and 250 HP have hydraulic and 270 and 290 HP have mechanical. Your generator drive was likely removed. Check the tag to determine which part number your generator is. You can purchase generators and tach drives. Your 5500 tach is correct for the 230 HP engine. You just need the generator and generator drive unit. An easy install. Bruce is correct about the gearing. (Bruce is a sharp guy and his advice is always good.) I have a couple of AC 8000 RPM tachs and converted one for generator driven use. Bruce's gearing is correct as mentioned. Steve
                • Steve V.
                  • June 27, 2011
                  • 95
                  Re: Tach too fast
                  Did any of the carburetor engines have a distributor driven tach?
                  Steve
                  Thomas Edison
                  • Ray K.
                    • July 31, 1985
                    • 375
                    Re: Tach too fast
                    Steve,
                    The 1962 Corvette was the first to use a distributor driven tachometer for carburetor engines.
                    Ray
