1954 Firewall Fiberglass Repair Advice Needed - NCRS Discussion Boards
  • John L.
    • February 1, 2005
    • 207
    This is a follow up posting to a previous thread I had for fiberglass tunnel repairs - 1954 Tunnel Repair for Floor Shifter.
    I have a good sized cut out on the firewall of my 1954 which I need to patch in and thought I would post this question for some advice on how to approach this.
    This is a photo of what the firewall should look like...
    My plan was to create a mold that would replicate the 90 degree bend (perhaps using a 2x4) and with that create 2 panels, and then would mate the 2 lips together adding rivets then this assembly would be cut and fit into the firewall.
    Would this seem to be an effective approach? If the repair were limited to an area above or below the joint it would not be as bad but of course the hole is in both panel.
    Any advice or direction appreciated.
    John
  • Chris S.
    • January 1, 2000
    • 1068
    Re: 1954 Firewall Fiberglass Repair Advice Needed
    easy fix !!
    take cardboard and tape it to the back of the hole
    take a sharpie or pen and scribe the hole on the cardboard
    cut the cardboard
    Lay the template on some flat used fiberglass
    cut it out
    trim the fiber glass to fit the hole
    Tape the glass on the back
    V groove - fill etc.......
    for the "lips" - glue them on after the repair - using old fiberglass
    sand to look OEM - replace the rivets
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • John L.
      • February 1, 2005
      • 207
      Ha I wondered if that would be the other approach - seems much simplier.
      Thanks!
      John.
      • Chris S.
        • January 1, 2000
        • 1068
        It is pretty simple
        once to do some repairs - it is pretty easy
        Take your time
        have the right materials and tools
        If you screw it up - guess what ?? you can re do it !!!!!
        If I can do you can do it
