Ncrs classified adverts. - NCRS Discussion Boards
  • Michael J.
    • January 27, 2009
    • 7122
    #31
    Re: Ncrs classified adverts.
    OK, it took 7 tries but it finally accepted my old password, mission accomplished.
    • Jack H.
      • April 1, 2000
      • 477
      #32
      Already part of my daily web routine. Thanks to everyone involved in making this happen.
      • Dale C.
        • November 1, 1999
        • 844
        #33
        I posted a 68 SB smog system and went to check on it today and it was not there. I hope it was not too offensive or something. My bad I fount it.
        Dale
        • Gary C.
          Administrator
          • October 1, 1982
          • 17697
          #34
          Dale,
          Go to the classified ads home page https://www.ncrs.org/classified/index.php
          Search on smog pump
          And You'll get your smog pump listing, which is in the:
          Category: Main > C3 Parts > Engine Parts
          Or on the home page you can page down and click on C3 Parts
          Or you can login and select My Account and My Active Listings
          Gary
          NCRS Texas Chapter
          https://www.ncrstexas.org/
          • William D.
            • April 1, 1993
            • 101
            #35
            I am having same problem! will try again later
            1965 Conv 327/365HP 4 sp, 3.73, KO's, pb 96.6 pts
            1965 Coupe fuelie, F40, 411's, teak/tele, 32K, 98 pts
            • Donald H.
              • November 2, 2009
              • 2580
              #36
              You may just be rushing the password reset a little. When you reset your password, it take about 5 minutes for the script to run that synchronizes the passwords between the TDB and the Classified Ads software.
              Don Harris
              Don Harris
              • Gary B.
                • February 1, 1997
                • 7024
                #37
                Don Harris
                Don,
                Maybe your 5-minute estimate varies with how busy the server is. When I went thru the non-reset, "reset" process it took less than 30 seconds.
                Gary
                • Donald H.
                  • November 2, 2009
                  • 2580
                  #38
                  Actually what I meant to say, was that the script that synchronizes the passwords runs every 5 minutes, so it could be a few seconds or up to 5 minutes for the sync to take place.
                  Don
                  Don Harris
