A Few Under Dash Questions ( 66) - NCRS Discussion Boards
  • Jim S.
    • March 1, 1986
    • 1399
    I have a few under dash questions as I can't seem to find either item in my 66 AIM.
    Question #1
    Do I have the wiper arms in their proper location ?
    If the pictures aren't sufficient , they are as follows . Passenger side set at 5:00 O'clock...Drivers side set at 1:00 O'clock . In the center it is passenger over driver as per UPC 1 D3.
    Question #2
    Is this Silver Bracket supposed to attach to the fire wall and the two corresponding screws on the duct assembly ? I can't imagine where else it would go to , however it is quite a gap to those screws ,
    there is a lot of duct work left to attach , and again I can't find any mention of it in the aim.
    As always Thanks for your attention.
    Jim
  • Russ S.
    • April 30, 1982
    • 2162
    Re: A Few Under Dash Questions ( 66)
    wipers are correct.
    • Page C.
      • February 1, 1979
      • 802
      The bracket supports the air condition heater box. It should bolt to the back upper corner of the heater box with a couple on hex head black phoshate screws. I would loosen the bracket from the firewall stud and attach it to the heater box first.
      • Jim S.
        • March 1, 1986
        • 1399
        Thanks Russ . Good to know !
        JIm
        • Jim S.
          • March 1, 1986
          • 1399
          Thanks Page ,
          That's what I thought , but two thing kept me from being certain .
          One , the gap or distance between them is large and that box doesn't flex much . Two, I don't know why I didn't take it off with the box when I removed it originally.
          Jim
