My worn & flattened cam is part#3863144. On rebuild heads will be original square port w stock rockers, push rods & valves no porting/polishing, tri-power carbs. I can do a) replacement stock mech cam, b) Comp Cams, Crane or others' "exact repro" w/their "premium" components, or c) hydraulic equivalent if that exists.
I'm not afraid to set/adjust lash, and I need the sound & performance of original. That said I doubt I'm going to spend a lot of time at 5000 RPM or above so perhaps don't need original mech cam/lifters? The thought of hydraulic set it forget it is appealing but not if I'm going to sacrifice sound & performance in the normal 2000 - 4500 rpm range. Any opinions much appreciated.
