67 Corvette Chassis plating help for two bolts - NCRS Discussion Boards
  • Thomas N.
    • July 31, 2002
    • 401
    I'm trying to determine the proper finish for two bolts on my chassis. The first is the cross bolt that the emergency brake pulley rolls on. Should this be zinc plated or black phosphate? The other bolt is the upper bolt on the idler arm. Should this be zinc plated or black phosphate? The longer lower bolt is phosphate, but I am not sure of the small upper bolt that mounts to the frame tab. I've seen pictures and catalog items showing these either way,but am not sure of what is proper. Thanks for any responses.
    NCRS New England Chapter Chairman 2022, 2024
    N E Regional Chairman 2024
    1967 Corvette Convertible Under Restoration
    1996 Corvette Coupe NCRS Chapter Top Flight 99.5, NCRS National Top Flight 100.0
    • 6950
    Re: 67 Corvette Chassis plating help for two bolts
    Tom I am pretty sure the idler upper bolt and nut is black phos. both my 63 and 72 have that finish. The bolt for the e/brake pulley I think its likely Zinc. but not really positive.
    • Patrick B.
      • August 31, 1985
      • 2003
      The emergency brake pulley bolt on my 67 was black phosphate.
      • Steve L.
        • June 30, 2001
        • 763
        My personal records show both are black phosphate on my 73
        Steve L
        73 coupe since new
        Capital Corvette Club
        Ottawa, Canada
