1979 Sound Deadener - NCRS Discussion Boards
1979 Sound Deadener
  • Schanen C.
    • February 1, 2010
    • 122
    1979 Sound Deadener
    Hi All,
    Has 79s from Factory Sound Deadeners Front and Rear ???
    Paragon has this deadeners.
    And are these Correct for my Car.
    Rgds.
    Carlo
    • 6950
    Re: 1979 Sound Deadener
    Schanen, I am pretty sure you find a insulation under your carpets front to back and on the convertor side it may have a foil on the under side. In any event I would use a heat barrier with the insulation. It will help with cabin heat. They make a 1/4" heat barrier that works great I installed on my 72.
    • Schanen C.
      • February 1, 2010
      • 122
      Hi Ed,
      Thanks for the Answer.
      Carlo
