67 M35 pan - NCRS Discussion Boards
67 M35 pan
  • Keith B.
    • March 7, 2008
    • 928
    67 M35 pan
    in the new manual it states that no drain plug was used. on my dads original pan i has a drain plug. it does not look like it was added after the fact. it uses a 7/8 hex head plug (like used on oil pans). here are some pictures
    here is the stamp on the side of the pan. the car was built the second week of June 67
    out side the pan
    inside
  • Russ S.
    • April 30, 1982
    • 2162
    Re: 67 M35 pan
    As you now know they did use a drain plug.
    • Keith B.
      • March 7, 2008
      • 928
      Re: 67 M35 pan
      So is that a error in the new manual? If so what can I do when it comes time to have it judged
      • Russ S.
        • April 30, 1982
        • 2162
        Re: 67 M35 pan
        I suspect most C2 and 67 judges know this. Bring your pics along that show stamping.
        • Keith B.
          • March 7, 2008
          • 928
          Re: 67 M35 pan
          Just odd they forgot to fix this for the new manual.
          • Page C.
            • February 1, 1979
            • 802
            Re: 67 M35 pan
            Hi Keith,
            In looking at the date code on the pan (T7E25D), T=Toledo, Ohio, 7=year, E=Month of May, 25+day of the month. Do you know what the D indicates.
            There is a very good article on Aluminum Powerglides by Jerry Duffey in the current issue of MAC Chapter Signal Seeker Magazine available online through the NCRS website.
            • Keith B.
              • March 7, 2008
              • 928
              Re: 67 M35 pan
              Page
              thanks for the heads up on the article I will have read that. I was thinking the D was the shift or line. But I have no clue. I was hopping you or someone else would answer that
              • Russ S.
                • April 30, 1982
                • 2162
                Re: 67 M35 pan
                On earlier cars the D (or N) was day or night shift.
                Originally posted by Page Campbell (2299)
                Hi Keith,
