Source for brake lines - NCRS Discussion Boards
  • Timothy B.
    • April 30, 1983
    • 5186
    Has anyone bought brake lines from a company called Inline Tube.com. I am curious about proper bends and fit compared to the original lines.
  • Keith B.
    • March 7, 2008
    • 928
    Re: Source for brake lines
    can't say anything on inline tube. but I just put on carbon steel lines sold by lone star Corvette for a 67 and they fit fine. But for inline tube I used them for my 66 Chevelle with no problems
      • 15599
      I used InLine Tube for my 1967 Chevelle, but of course that doesn't help you with Corvette. I was, however pleased with their service and responsiveness, and in spite of being a not-quite-stock application (conversion to 4-wheel disks) they fit fine. A good company to deal with.
      • Mike E.
        • June 24, 2012
        • 920
        Not knowing any better I bought all my blocks and lines from Ecklers. They seemed to fit fine with little or no tweaking. All suppliers ship main front to rear lines with a gentle bent and you have straighten them out which is a little tedious. Other then that no issues.
        Mike
        • Mike E.
          • June 24, 2012
          • 920
          Here are some shots of the crusty old lines. Ha...I just noticed the T/A bolts were put in backwards, Bubba strikes again.
          Mike
            Mike -
            Chassis looks great! That cup-shaped washer at the lower rear shock mount should be reversed - the flared side should face inboard.
            • Mike E.
              • June 24, 2012
              • 920
              Mike -
              Thanks John...Easy fix... We are talking about #8 from this sheet on the AIM?
              Mike
              • Timothy B.
                • April 30, 1983
                • 5186
                Mike, I agree, your chassis looks very nice. It's the #8 in the pic you mentioned.
                Does inline tube supply the vendors or do they all make there own lines.
                • Larry M.
                  • January 1, 1992
                  • 2690
                  Tim:
                  Some years ago, I believe that there were four (4) main companies supplying reproduction brake and fuel lines for our cars: Classic Tube, Inline Tube, FineLines, and one I can't remember right now. I believe that they supplied most of the market. When I bought my brake lines from DR Vette (now CSSB Inc) they were made by FineLines.
                  As best I can determine Inline Tube may be the best out there at this time. If not, they are still very good.
                  Larry
                  EDIT: Fourth company I mentioned above was called/named "The Right Stuff".
                  • Mike E.
                    • June 24, 2012
                    • 920
                    I looked at the Master Cylinder line that I did not install yet and it had a tag from Corvette Stainless Steel Brake. BTW they are steel lines.
                    Mike
