LT1 hood question - NCRS Discussion Boards
LT1 hood question
  • Martyn T.
    • February 1, 2000
    • 39
    LT1 hood question
    Does the LT 1 hood have more vertical air cleaner clearance than a stock sb hood ? If so how much ?
    Marty
  • Lyndon S.
    • April 30, 1988
    • 1027
    Re: LT1 hood question
    I would say no, the hood has only a slight rise in the front away from the air cleaner. The hoods were for the most part just styling.
      • 43271
      Marty
      Martyn------
      Yes, it does. How much I do not know. I don't know if a 68-72 stock style hood would clear an LT-1 engine installation. However, the LT-1 style hood was also used on big blocks. A 68-72 stock-style hood will not clear a big block installation; a big block hood is required.
      • Kenneth B.
        • August 31, 1984
        • 2091
        Martyn------
        Right again Joe. About 2" or so & tapers back slowly to the cowl where it is flat like the SB hood.
