65 clutch swing arm - NCRS Discussion Boards
65 clutch swing arm
  • Bill W.
    • March 1, 1980
    • 2000
    65 clutch swing arm
    Just finished cleaning my clutch swing arm . It had two different types of grease inside , White and normal ball joint type grease . What is the correct type of grease to use ?
    • 6950
    Re: 65 clutch swing arm
    Bill, I would think the white grease may have been what the factory used. wheel brg. grease is likely what some lube tech. installed sometime in its life. I would say either would work just fine. use a few drops of 80w90 gear oil on the felt washers at each end to help keep things wet.
