Im trying to figure out which way to feed the harness thru the 1 inch hole in the firewall. I started to feed the insrument wires thru from the engine side buy doent seem to work. The thickness of the harness and light bulbs seems too much. Also doesnt seem the column connectors will go thru with the thickness. They must of had a proceedure at the factory. Is it better to feed the engine side of the harness from inside the car because doesnt seem the the point where it takes off to the generator, that junction, will fit thru that hole without really compressing it. How did you folks feed it? Thanks as always.
