For those that have followed my thread HERE, related to the engine problems I've encountered, we have been trying to figure something out. I'd like your opinions as to what may be causing this unusual effect when the engine reaches it's "coolant expulsion" state. We cannot come up with a answer.
The horse is dead but we're eventually doing an autopsy before this block becomes a marine reef. This is alike rearranging deck chairs on the Titanic, but want to try to understand it as a learning experience.
This engine has NEVER reached a temperature overheat condition. Maximum temperature ever recorded in all (10 or so) "over/out flow" running tests has been about 195*.
As a refresher, here is the short clip of what happens when the diagnosed combustion gasses have pressurized the cooling system when NO radiator cap is present. After reaching apx 180* IR gun temp at the thermo housing this is what happens.....
Now the following is what we all cannot understand.....
When a 13lb radiator cap is present (pressure tested pass), when the engine reaches apx 180*, a violent burst of the lower radiator hose blows it clear off the water pump loosing the coolant. BTW we've used water for all tests. This cooling system is brand new with Dewitts Top Tank rad, all new hoses etc. Take note that the lower radiator hose is attached to the water pump with a stainless steel WORM CLAMP. This after my thinking the Corbin clamp was defective. It wasn't.
We cannot understand why this happens. Imagine the huge air bubble growing inside the cooling system from the combustion pressure building up. The water pump(rebuilt original) hose nipple does not include a ridge at the edge. It is a smooth pipe at attachment. Most pumps are built this way as I have seen.
Is it possible that this is just due to expansion, the pressure being below 13lbs and has no where to go? As it increases I would think that it would gradually open the radiator cap pressure relief to release pressure into the overflow tank and out the overflow hose.
It appears the hose connection at the WP is the weakest junction in the cooling system and that's the release point. I'm glad it wasn't the heater core or valve, or the radiator itself. It's acting like a pressure cooker, and the temerature rises rapidly before it explodes.
Rich
Rich
